Use the following procedure to generate the private and public key pair for the specific cryptography type.
- Select Certificate.
- Select the Key-Pair tab.
- Select Insert.
- In Type, select the cryptography type.
- In Size, type the size of the key.
- Select Insert.
Key-Pair Field Description
Use the data in the following table to use the Key-Pair tab.
Name |
Description |
Type |
Specifies the cryptography algorithm used to generate the key-pair. Only RSA is supported. |
Size |
Specifies the size of the key-pair to be generated. Only 2048 is supported. |
Name |
Specifies the name of the key-pair generated for the subject. This name is auto-generated as the combination of key-type and key-size. |
